If you are looking for a great street/track suspension that won't break the bank or you just want an upgrade to the stock suspension this is for you. I will go over each step in the order that i did them. I am sure you could do them in another order however this is just what i did. I will give as much detail as i can. I will give a list of items that i bought and will provide links if i can. I will update this list Monday to include the actual dollar amount spent on this setup but i think its well under 600$.
Basic hand tools will work for the most part. An impact driver of some kind is highly HIGHLY recommend for the rear lower strut mount bolts (easier to get them out without damaging the bolt or weld in nut). If you dont have an impact driver go buy an electronic one from Harbor Freight (http://www.harborfreight.com/12-in-h...nch-61173.html) its really its not a bad tool-just take care of it and it WILL last. You will also need a jack, jack stand (the stands are for safety only- NOT ACTUALLY NEEDED-BUT GET AND USE THEM). You will need a way to grind or trimm a small metal bushing. You will also need a way to drill a hole in metal or widen the hole already there.
If all goes well you can have the suspension done in one day easy. If you end up having to fix other issues i could easily see this taking a weekend. I had to cut one rear bolt out and ended up doing the install over 2 different weekends. So plan ahead of time. Do not rush this.
Shopping list: You might be able to use other items- This is just what i did.
1. 1x kit- VW Golf MK2 Coilovers (you will use only the front)-ebay-
Get a set that looks like this. I would post a link, but they change sellers and links very frequently.
![](https://i.imgur.com/Ho4Lzu2.png)
2. 2x- VW Golf MK1 rear KYB Struts 341007 KYB (you will use these struts to build your custom rear coilovers)
3. 2x- 36MM BILSTEIN coilover sleeve kit (this will allow you to run a small O.D. spring) https://www.southwestspeed.com/?sec=view_part&id=1049
4. 2x- 2001 (2 bolt style) Kia Rio front Strut Mount- i bought from ebay
5. 2x COILOVER SPRING,1.87 ID X 10" X 105# (these will be for the rear diy coilovers) https://www.southwestspeed.com/?sec=view_part&id=22
6. 2x COILOVER SPRING,2.5" ID X 12" X 120# https://www.southwestspeed.com/?sec=view_part&id=65
7. Volkswagen Golf 2000-01,Jetta 2001-05 Rear Shock Bumper SET OF 2 NEW 1J0512131B (these can be used in the rear to help limit travel to give better handling)
PLEASE DONT POST UNTIL I HAVE FINISHED THE STEP BY STEP INSTRUCTIONS- I WISH TO KEEP THIS CLEAN FOR OTHERS IN THE FUTURE.
