I know you can use a string and a carpenters square, but I want to set my rear tires as well as do the fronts nicely. I have no where level to park. So which style should I get for measuring the camber? Is a cheap bubble levelish one like this that goes on the rotor for $35 ok? http://www.ebay.ca/itm/New-Magnetic-...YI&vxp=mtr
Or should I get a digital one the goes on the rotor for $270? http://www.ebay.ca/itm/LONGACRE-DIGI...Ow&vxp=mtr
Or should i get a bubble level one that goes on your rim for $200? http://www.ebay.ca/itm/SPC-Performan...Uu&vxp=mtr
I'm not racing with this, just want it close for a nice comfortable long road trip with no tire wear
Then for toe. I could buy toe plates for $85 http://www.ebay.ca/itm/Longacre-Raci...3D191348212924
But I am thinking of finding some really straight boards instead may be a better option. Or should I really go with something like a manufactured toe plate?
Are you guys buying this stuff from local stores or online? If local stores then what kind of stores? All the above prices I posted are CAD but before shipping and shipping to Canada is usually a lot.
Then for rear camber/toe shims where is the best (cheapest) place to buy them? I found that someone posted a link to these, but no size specs on them. I thought you had to get different sizes and that they weren't a one size fits all? http://shop.advanceautoparts.com/p/m...ral#fragment-3
To level the car I plan to use linolium or ceramic floor tiles, cheets of paper, whatever, to shim up whichever side is lower and use a 5ft level I have.
In some of the threads I read on this forum using laser levels was mentioned but not their purpose. What do you use them for?
