PINPOINT TEST FW: FRONT WINDOW WIPERS
FW5 CHECK FRONT WIPER MOTOR GROUND CIRCUIT
l Key OFF.
l Disconnect the front wiper motor connector.
l Measure the resistance of the following wires between the front wiper motor connector and ground under the following conditions:
Front Wiper Switch Position             Wire                     Resistance
 OFF                                              BL/BK           Greater than 10,000 ohms
                                                    BL/W            Greater than 10,000 ohms
                                                    BL/R              Greater than 10,000 ohms
Low                                                 BL/BK           Greater than 10,000 ohms
                                                       BL/W            Less than 5 ohms
High                                                  BL/BK          Greater than 10,000 ohms
                                                        BL/R             Less than 5 ohms
One-Touch                                         BL/BK           Greater than 10,000 ohms
l Are the resistances OK?
Yes
REPLACE the front wiper motor.
No
GO to «FW6».
