PINPOINT TEST FW: FRONT WINDOW WIPERS
FW6 CHECK WIRES BETWEEN FRONT WIPER MOTOR AND FRONT WIPER/WASHER SWITCH
l Key OFF.
l Disconnect the front wiper motor connector and the front wiper/washer switch
connector.
l Measure the resistance of the following wires between the front wiper motor
connector and the front wiper/washer switch connector:
³ Wire ³
³ BL/BK ³
³ BL/R ³
³ BL/W ³
l Measure the resistance of the wires listed above between the front wiper motor
connector and ground.
l Are the resistances less than 5 ohms between the front wiper motor connector
and the front wiper/washer switch connector, and greater than 10,000 ohms
between the front wiper motor connector and ground?
Yes
(Wipers do not park)
GO to «FW8».
Yes
(Wipers do not operate)
GO to «FW7».
No
SERVICE the wire(s) in question between the front wiper motor and the front
wiper/washer switch.
