PINPOINT TEST FWS: FRONT WASHER SYSTEM
FWS3 CHECK FOR SHORT TO GROUND
l Key OFF.
l Remove the 15A WIPER fuse.
l Disconnect the front washer motor connector.
l Measure the resistance of the "BL" wire between the bottom terminal of the 15A WIPER fuse holder and ground.
l Is the resistance less than 5 ohms?
Yes
SERVICE the "BL" wire.
No
REPLACE the 15A WIPER fuse. GO to «FWS4».
