PINPOINT TEST RW: REAR WINDOW WIPER
RW4 CHECK POWER SUPPLY TO REAR WIPER MOTOR
l Key OFF.
l Disconnect the rear wiper motor connector.
l Key ON.
l Measure the voltage of the "BL/O" wire at the rear wiper motor connector.
l Is the voltage greater than 10 volts?
Yes
GO to «RW5».
No
SERVICE the "BL/O" wire between the interior fuse panel and the rear wiper motor.
