PINPOINT TEST RW: REAR WINDOW WIPER
RW5 CHECK REAR WIPER MOTOR GROUND CIRCUIT
l Key OFF.
l Disconnect the rear wiper motor connector.
l Turn the rear wiper switch on.
l Measure the resistance of the "BL" wire between the rear wiper motor connector
and ground.
l Turn the rear wiper switch off.
and ground.
l Is the resistance less than 5 ohms with the rear wiper switch on, and greater
than 10,000 ohms with the rear wiper switch off?
Yes
REPLACE the wiper motor.
No
GO to «RW6».
