PINPOINT TEST RWS: REAR WASHER SYSTEM
RWS3 CHECK FOR SHORT TO GROUND
l Key OFF.
l Remove the 15A R.WIPER fuse.
l Disconnect the rear washer motor connector.
l Measure the resistance of the "BL/O" wire between the bottom terminal of the 15A R.WIPER fuse holder and ground.
l Is the resistance less than 5 ohms?
Yes
SERVICE the "BL/O" wire.
No
REPLACE the 15A R.WIPER fuse. GO to «RWS4».
