So we take aspire drums and cut the unneeded part of them to turn them into hubs
take a 1/4 inch steel plate and some mazda mx-3 rear brake calipers and rotors
(that probably means a v6 mx-3), bolt the caliper to the plate through some sleeves with some 50mm class 10.9 bolts
paint calipers yellow
And we are ready to roll!
Escort GT/Protege LX calipers seems to be compatible in terms of how they mount, but use slightly different pads.
I wanted aspire drums for the aspire bolt pattern anyway - but see how close the holes are to the edge of the drum (and the drum side is dictated by the brake rotor diameter) - seems like festiva drums would not work.
No E-Brake in this design - I live in a flat state and my e-brake is broken for a while already anyway
PS: wonder if anyone would be interested to buy a bolt-on kit consisting of these brackets, sleeves and hubs? But that would probably be $199 shipped, and you will still need calipers and rotors.
