my rear disc brakes
  • my rear disc brakes
    So we take aspire drums and cut the unneeded part of them to turn them into hubs
    take a 1/4 inch steel plate and some mazda mx-3 rear brake calipers and rotors
    (that probably means a v6 mx-3), bolt the caliper to the plate through some sleeves with some 50mm class 10.9 bolts
    paint calipers yellow
    And we are ready to roll!
    Escort GT/Protege LX calipers seems to be compatible in terms of how they mount, but use slightly different pads.
    I wanted aspire drums for the aspire bolt pattern anyway - but see how close the holes are to the edge of the drum (and the drum side is dictated by the brake rotor diameter) - seems like festiva drums would not work.
    No E-Brake in this design - I live in a flat state and my e-brake is broken for a while already anyway
    PS: wonder if anyone would be interested to buy a bolt-on kit consisting of these brackets, sleeves and hubs? But that would probably be $199 shipped, and you will still need calipers and rotors.
    rusEfi - DIY ECU
    93 EFI: tach cluster, aspire mirrors & spindles. ZX2 master cylinder, BP+G25 swap with a door hinge, rio struts. 205/50r15, 140mph speedometer,rear disk brakes, mini cooper + subaru front brakes rear sway bar
    How much offset would you say that adds?
    Current cars:
      On the one hand, you add a 1/4 inch plate between the beam and the axle stub/spindle. On the other hand, you remove drum disk back plate, which is maybe 1/8 or a bit less around the axle stub.
      rusEfi - DIY ECU
        Very creative!
          Originally posted by TominMO View Post
          Very creative!
          We both know this was done before
          rusEfi - DIY ECU
            If anyone's interested I know a guy who's got a couple sets of old/used aspire drums that could be cut up for this. Of course, he wouldn't be responsible for what you did with them. Feel free to pm me.
            2008 Kia Rio- new beater
            1993 Festiva- Fiona, DD
            1997 Aspire- Babyspire, DD
            1994 Aspire - Project Kiazord
            1994 Aspire- Crustyspire, RIP
              Can you tell me if the VW Golf brakes will work? They have 4x100 and e-brake built in.
                Picks of the welded assembly?
                Going old school...
                  I would be more inclined to do this type of brake conversion as I live in an area made of hills, and I'm a teenage boy so I need my oversteer bar
                  Kellen
                  Owner of:
                  1991 Red Festiva L, 5 speed (Swagger Wagon)
                  In progress:
                  BP+G25MR swap, Kia rio axles hopefully.
                    If I understand right discs grab better than drums. Now that you've figured out a cheap and ingenious way of putting them in the back have you had to play with the brake proportioning valves at all?
                    Neat idea you have there.
                      As I said, not my idea - this was done by Stevo back in 2004.
                      As for proportion - good point, but I comfort myself by the fact that fronts are also not stock. Also I am going to use sporty pads on the front with regular pads on the back.
                      rusEfi - DIY ECU
                        Ops, I have forgotten about the brake rotor - it also adds some offset since it's between the drum and the wheel.
                        rusEfi - DIY ECU
                          If by "both" you mean "you", then you are correct! I have not seen this before.
                            I really don't know, are they hollowed inside with brake shoes that expand out on the inside of the rotor like Chrysler minivan rear disk brakes? If they are I would think the whole rear axel setup would need swapped, but thereto again, I don't know.
                              People on here may already know this, but Capri rear discs fit right on Festiva stub axes, but then you are left with the 4x4.5" B/C. I still think there are lots of great wheel choices in that pattern though (may favorite O.Z. wheels are cheap in that pattern). I was just going to use that setup with some wilwood 2 piston calipers and a hydro hand brake, but I've had great luck with my drums.
                              Great idea with the machined drum, I bet the Miata rear brakes would work for this too, and they are available in 2 piece rotors from wilwood.
