I picked up the Pioneer combo for $100 at Best Buy Friday, and proceeded to install in my festiva. I just traced a circle for the rear speakers on the rear decks and went at it with a dremel. For the front I originally did the same thing, but the window cranks were hitting my speaker grills. I then cut the hole the size of the speaker grill diameter, and mounted the speakers right to the door(metal). You might not be able to do this with deeper speakers because I have about 1cm of clearance with the glass and the speaker when the window is down. My car did not have previous door wiring so it took a long time to run the wires to the speaker. Hope you guys understand what I did. Hit me up with any questions.
Here is a vid with an explanation.
Kevin
Kevin
Poverty produces creativity
