Is there a way to test a radio off the car? I took the old ratio out and hooked up the second hand replacment but it won't turn on, ie won't light up. So I hooked the old one back up and it won't turn on either. So I used a voltmenter to check the power line on the car was good (both the always hot and the key-on/ACC hot wires) and I connected just the power and ground but neither radio will light up. I trieed the ground wire and grounding directly to the metal the radio scews onto. I have a battery charger. Would it be safe to use that as a power source to test if the radios light up? Other ideas? I don't need to connect the speakers yet, just see if the radio powers up.
Testing radio off car?
I wouldn't test a radio without hooking up speakers.Not sure if it is still an issue but used to be running a stereo or amp with no load, as in no speakers would burn up the output I.C. learned the hard way once, did it twice but learned on the second one.Even argued with a guy that told me that would happen, because in my mind I figured if nothing shorted nothing would be hurt.And. I have used my battery charger many tomes to check stereos I just wire them up like they were going in a car, speakers amps and all the substite the battery charger for a battery.Never did that for more than a minute or so but for testing that's how I've done it.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
