aftermaket radio HeLp!!!
  • aftermaket radio HeLp!!!
    hey guys i have a 1988 festy carb i tried to install a after maket cd player and got it workin the first shot only problen was that it stuck out alittle. one day my bright mind said if i change the nut in the back were the ground is it would fit better so i took it out changed the nut and put it in then nothing no power to the radio at all so i took it to best buy and replaced all the fuses but when i pluged everything back in i got power but no sound it sounded like static threw the speakers and the ground was getting hot enought to start a fire..... were did i go wrong and what do i need to do were do i put the grounds from the car and the radio so i dont blow up my car please help
    it sounds like you got a short somewhere check thet all your wires have no metal spots showing and that there is no little barbs in the wire that could be grounding it out.
    Mike, AKA the sasquatch
      i took it out welded everthing properly then used liquide electrical tape around the weld so i know there was no prob there theres power remember just no sound it cost over 60 for them to install it at best buy
        like he said. sounds like a short. check your wires. i just put in another today. had power and staticy sorta but i had a wire on the speaker in my door that came loose and was grounding the whole system on the door. check it out bud. check against a wiring diagram.
        Redlands, CA
        1995 Ford Aspire [Red]
          ok thanx yall ill see what i can do
            Def. sounds like a bad ground amongst the wiring, Or I have seen this before when the antenna is bent wrong or to far.. HOPEFULLY its just a wire loose somewhere easy to get to and easy fix.
            Your never famous til your dead!
