Battery Relocate help needed
    i will show you some pics here in a bit... but as of now i have 2 12" subs, 8 6" speakers, and 4 1" tweeters off of two amps, as well as a 17" LCD screen in the car.. But i am looking at putting 2 more 12" subs in the car as well as another set of underglows... so i need a little bit of battery power.. haha
      What do you have for an alternator in there??
      90 Festiva with Brand new B3, 5spd
      92 B6 Festiva, 5spd
        I can't remember which gauge wire I used, but it was slightly bigger than stock, and to be on the safe side, I ran twin positive wires to mimick the stock wires, ran them from the trunk, under the carpet, through the driver's door sill, them followed the harness through the door pillar and on top of the fender well (between the fender and engine compartment's left side) through a hole in the engine compartment's left side and connected it with the remains of the factory positive battery cable. For the negative, I grounded it to the bolt of the hatch latch. Oh, and I'm using a stock battery in the trunk, on the driver's side, just missing a battery case. No problems with charging whatsoever.
          i have an alt from http://www.nationsautoelectric.com/e...ternators.html.. it is a 200 amp alt and came with an adapter piece to use on the festiva
            Wow...200 amps!!! How long have you been running that??
            92 B6 Festiva, 5spd
              You don't need more batteries in the vehicle. The battery is only there to start the car, when it is running all the elctrics run off the alternator. If you are having problems with charging now you would need to run a bigger alt. But I would think 200 amps would be ample. By the way a 17inch screen would look massive in a festy, is it mounted in the boot.
                haha.. yea i am going to have it set up in a series with the batteries.. one wire from the alt to the main battery, then to an isolater, with the other two hooked up directly to the amps. and one of the monitors is were the back seat should be at and the other will be in the back window facing out on a hinge to swing down for at car shows... will get some pics up as soon as i can... possibly tomorrow with how it looks as of now..
