I'm not a big stereo guy. I pulled my front speakers out and there round in square plate. I figured they were were 4" but all the 4" speakers I've looked at on the net seem to be round. what size am I looking for?
speakers?
hmmmm just double checked the speaker itself is 4" but the square mounting bracket has got me baffled I was gonna order some off ebay tonight. but I'm not sure if the 4" ones with the round plate will work as well. danm guess I'm gonna have to go down to an audion shop and feel like a newb.93-1.6l
f.s.- fms bodykit.
4 inch front and rear. You can make pioneer 5.25s work in the rear(probably any 5.25, but I used Pioneers without too much hassle). But you are stuck with 4" up front, the hole pattern is standard and any 4" speaker should work.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
^^^^^^ What he said....just got done replacing all four.1989 Red L- The Baron
www.letstalkbeatles.com
Link to Baron Pics:
http://s478.photobucket.com/albums/r...nmervap/Baron/
1990 White GL- Chuck (for now)
actually i put 6 1/2 in the front doors with very little modificationwindows work and everything, and i have 6 1/2's in place of the rears, that took a little more modification but its deffenatly not out of the question
(GONE)88 Festiva LX 5 Speed, Factory A/C, Factory Tow Hitch, Tach.
95k Original miles
New: Tires, Axels, Front Wheel Bearings, Fuel Pump, Valve Cover Gasket, Carb Rebuild, Timing Set, Belts, Shoes, Distributor, CapRotor, Wires, Plugs, Coil, Grant 11" Steering Wheel, 3700 Watt Stereo System-6 1/2 Infinity speakers, Infinity tweeters, Almani 12" subs
got some cheap speakers for 16.99 from princess auto. do the trick got 4 speakers now. sounds alright and clearer then the blown stockers. danm long weekend I can't get down to any parts stores till tuesday to get anymore goodies.93-1.6l
f.s.- fms bodykit.
i replaced all the speakers in mine as well as added some 6.5 ones in a back dash i made for it and they aound awesome with the aftermarket pioneer deck and custom sub system i put in it. the front ones went in just fine but the back ones i had to make a bracket for since the holes were i lil off. i think in a few weeks though i will be changing them all back out so they all match though instead of bein just a big mismatch of speakers. that and i think i may have damaged the 4s in the back lol
