Radio Install: Color codes for wires for headunits (Radios)
This is a sticky topic.
  • Radio Install: Color codes for wires for headunits (Radios)
    This was submitted by Qaking,
    Hot at all times - WHT/RED
    Hot in run or ACC - BLU/YEL
    Interior lights - BLU/WHT & RED/BLK
    Left rear speaker - GRN & GRN/WHT
    Left front speaker - BLU/ORG & BLU/RED
    Right rear speaker - GRN/YEL & GRN/RED
    Right front speaker - BLU/BLK & BLU/WHT
    Ground - BLK
    I have not researched this yet, But, I believe it to be true. The only thing that I don't feel is accurate is the Ground. On my 89 L there was no black wire, I had to make my own ground. Make sure that you check the fuses after you install the head-unit if it does not power up, then check your ground. If all else fails, remember, a good digital Multimeter is your best friend.
    Eric
    "If it's too loud, Youre too old!"
    Get in, sit down, shut up, and hang on!"
    I agree with the ground, i dont know why it makes a difference on deck manufacturer though. My Jensen i had running to my black wire that was stock, and i put in a JVC and blew fuses until i ran a new ground wire
      Which are + and which are - ?
      89SX funtop! Fully loaded!
      RIP 90LX
        Re: Radio Install: Color codes for wires for headunits (Rad
        Ground - BLK
        Eric
        I checked these to a 1991 Festiva electrical manual and by looking at the speaker connectors:
        Interior lights - WHT/RED
        Left rear speaker - GRN (+) & GRN/WHT
        Left front speaker - BLU/ORG (+) & BLU/RED
        Right rear speaker - GRN/YEL (+) & GRN/RED
        Right front speaker - BLU/BLK (+) & BLU/WHT
        Ground - BLK
        Note about ground: my car has a short black wire that connects to the chassis at the rear of the space where the deck goes. This is in the electrical manual that I have so it's stock for the 91 Festiva.
        BP powered 91 Festiva L
        -FMS springs, GR2 struts, Toyo T1R 195/45/14 on Swift GT alloys
        -Trunk mounted gel battery
        -Suzuki Swift GT seats, Grant GT steering wheel, auto-locks
        -Blaupunkt Melbourne deck with Bluetooth, sealed single 12" sub
          Scan out of OEM Ford Manual
          Hope this helps -
          I apologize for the size of the picture but I did rotate it so that it wouldn't affect the thread width too much
          92 GL - parts car
          97 aspire - parts car
          87 323 DX - daily driver
            ford festiva 98 wiring codes
            hi guys...i want to install a cd player into my car instead of the headunit...does anyone know the wiring codes? im a little confused...because the cds second hand and does not have manual...
            cheers, megz
              What is the red with a blue stripe on it that runs with the other wires for the sterio????
                ok I have a problem, I'm trying to hook a cd player up and I get it to turn on then it turns right back off and wont turn on.. WTF?? I have it wired correctly and its getting power and ground, I am confused..
                  red w/ blue stripe i believe is for the dimmer
                  -Tim
                  93 Festy L- Little Red
                  98 Ranger- The golf ball
                  92 Accord- The $20 car (R.I.P)
                  73 F-100 (looking for a 302)
                  "Wait... you mean they pay people to fix their cars? Idiots..."
                    Hi, I'm about to install a new head unit and my Haynes has the same type wiring diagrams, but how do we know which is + and - on the wire diagrams? Thanks!
                    Semper Fi til I die!
                    1993 Fescort GT 1.8 BP automatic Kia Rio front struts and cut springs Cut Front Festiva springs with Monroe Aspire struts in rear
                      I don't think the Haynes manual tells which is pos or neg. Check out this website:
                      Question: Where can I find a 1990 Ford Festiva radio wiring diagram? What are the 1990 Ford Festiva radio wiring harness color codes? If you’re planning to…
                      It gives the radio wiring diagrams for any car.
                      1988 L - aka: Underdog
                      1990 L - soon to be trailer
                      1994 Aspire (Looks like an egg)
                        Car Radio Battery Constant 12v+ Wire: Blue/Red
                        Car Radio Accessory Switched 12v+ Wire: Red/Black
                        Car Radio Ground Wire: Chassis
                        Car Radio Illumination Wire: Blue/White
                        Car Stereo Dimmer Wire: N/A
                        Car Stereo Antenna Trigger Wire: N/A
                        Car Stereo Amp Trigger Wire: N/A
                        Car Stereo Amplifier Location: N/A
                        Car Audio Front Speakers Size: 4″ Speakers
                        Car Audio Front Speakers Location: Dash
                        Left Front Speaker Positive Wire (+): Blue/Red
                        Left Front Speaker Negative Wire (-): Blue/Yellow
                        Right Front Speaker Positive Wire (+): Blue
                        Right Front Speaker Negative Wire (-): Blue/White
                        Car Audio Rear Speakers Size: 4″ Speakers
                        Car Audio Rear Speakers Location: Shock Towers
                        Left Rear Speaker Positive Wire (+): Blue/Red
                        Left Rear Speaker Negative Wire (-): Blue/Green
                        Right Rear Speaker Positive Wire (+): Blue/White
                        Right Rear Speaker Negative Wire (-): Blue/Green
                        Previous owner of ZEFstiva
                          My wires are ALL different.
                          I have:
                          Grey/white
                          Grey/blue
                          Grey/red
                          Grey/yellow
                          Orange/white
                          Pink
                          Green/white
                          Black
                          Fast....Women are fast
                          Quick...Nestle is quick
                          I Speak French....in German! lol.
                            Please 'sticky' this thread someone. One day I will get a decent sound system installed in one of my cars. Truth be known I cringe every time I look at the crow's nest of wires that previous owners have taped together or left behind when the OEM radio died.
                              I 2nd the notion of sticky.. please do it.
                              Ford Festiva 1991 WA Model (5 Door)
                              Nicknamed the car 'The Chiva' (Chilli Festiva)
                              Avg Economy:
                              Highway - 7.32L/100km
                              City - yet to be determined.
