So I installed my sub/amp in my festy the other day but it's having a problem
Everything powers on and all is good. But when I turn the radio on and turn the bass up to loud everything basically stops playing when the bass hits.
Even though the bass is still barely noticeable.
Could this be a problem with my ground? I tried getting rid of the paint and trying different areas for my ground. Where did you all put your ground?
Is it where I connect to the battery?
The amp is pretty cheap its a tis 700 watt amp (not rms)
it has a 300 watt sub output and then 200 front speakers 200 rear speakers
The subs are two 12's mtx which are plenty capable of 300 watt
I've never hooked subs up and don't know much about it. So any help is greatly appreciative.
If you need more info on anything let me know
