Holy cow! I can't believe that was the problem. My friend was the one who hooked it all up (he's done it 100 times) so I just trusted it was right. Well they work now... Now I just have to tweak them to sound good. Thanks.
HELP! Sub/Amp
My Musica! Click me!
I was thinking the same thing as I was looking at the picture. I'm glad you got it taken care of.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
Now if you really want to help those subs out. Get some real speaker wire not that chicken wire youre using now.
Clean up the top of that battery as well. Dirt is a major power drain.Last edited by MONSOON; 01-07-2010, 04:48 PM.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Especially in the Winter. Salty slush is a pretty good conductor.Originally posted by MONSOON View Post...Clean up the top of that battery as well. Dirt is a major power drain.Festiva: Because even my dog can build a Honda.
I couldn't see any pics! Where did you ground? I've found that exiting the car and grounding to the frame works for me, but some people have called me crazy for that, but I use silicone to cover the assembly at the frame. I've also found that oversizing the gauge of the ground helps too, and buying the BEST wiring you can, no matter what the setup. Good wires on cheap speakers can sometimes sound the same as good speakers on crap wiring. Not saying you have cheap speakers; just being general.In love with a MadScientist!:thumbright:
your amp is shutting down because its not supplying the sub with enough power, i had 2 10"s hooked up to a kenwood 300 watt amp, didnt have an ounce of problem with that setup, then took the 2 tens out and put a 12" jl to it and same thing happened, worked great with no bass but as soon as it hit the amp would crap out and then regain then crap again when the bass came on, if you turn it down a little the amp would stay on, everything else worked fine and pioneer head unit03 Chevy S-10 Extreme-4.3
92 Ford Festiva GL-to be determined
92 Buick Roadmaster Estate Wagon-5.7
If you had read the thread or could see the pics he posted, youd have seen he had the power and rem wires crossed.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Yep I got it all figured out now and it's working perfectly. Thanks everyone for your help!
And don't worry monsoon that was just temperary Wiring I had brand new wiring to install just didn't have it on me.
Thanks everyone!-------------------------------------------------------------------------------------------
You wont regret going to a heavier gauge wire!Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
all that wire dose is turn on the amp when the radio tells it to.... on the back of the cd player there should be a wire that says somthing like remote or somthing on it... hook it to there but to make sure its the right wire test it with a volt meter, you should get 12V when the cd player is on and nothing when its off....
Mike, AKA the sasquatch
Rem stands for "remote" (I think) and is basically a .3 volt signal wire that tells the amp to turn on.........Sometimes I wire the amp such that it is always on, by bridging the rem and power wire (at the amp). I then go and put a switch on the power wire somewhere at the dash.
This is only suggestable when using a stock deck with no rem wire (old ones)
PS. I dont think you will get 12 volts out of the remote wire, as it should be only .3 volts total.........Last edited by Darlo; 08-20-2010, 11:48 PM.
That is correct.......It would be like hooking a light up to the power, and not turning on the switch. The rem wire is the "light switch"
ALSO, dont hook your amp up to a speaker. Your amp wants a non-amplified signal to amplify, and if you hook it up to a speaker, you will amplify an already amplified signal. This is not good for your amp. You need to get a line output converter. below is a link.
