So I'm installing a 2003 Civic cd player into the festy but there is a metal bracket right in the way behind where the cd player goes, and it's keeping the cd player from sitting flush in the hole. Does that bracket serve some super important purpose, or can I remove it? I haven't had a festy dash taken apart enough to know exactly what's going on in there, so I thought I'd ask for some input.
Bracket in way of installing cd player
Gone but never forgotten, "Hulkstiva"...http://www.fordfestiva.com/forums/sh...ht=progressionTags: None
Yeah, guess I'll have to get in there and see exactly what it's purpose is"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
I think if you get the "dash kit" for the festiva, it holds the player out a little further anyway. With that said, maybe it doesn't hold it out as much as you think.The normal is not always normal... MOST is not ALL... And any job can be hard if you don't have the right tools!!!
My Fleet:
Originally posted by doylerl View PostI think if you get the "dash kit" for the festiva, it holds the player out a little further anyway. With that said, maybe it doesn't hold it out as much as you think."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
hmmmm maybe its shorter than his. Or where your harness plugs in may not run into the bracket. Thats what it sounds like for his. His harness and cd player altogether is running into the bracket making it stick out.
Pictures of the bracket, the cd player and the dash would help us help you.:tard:
Originally posted by skinnypin View Posthmmmm maybe its shorter than his. Or where your harness plugs in may not run into the bracket. Thats what it sounds like for his. His harness and cd player altogether is running into the bracket making it stick out.
Here's the bracket in question...
Went ahead and cut it out...left the top portion which was screwed into something and holding the climate control unit...
Here's the 2003 Honda Civic cd player installed...
This is what the cd player looked like before all the trimming I had to do...it was oddly shaped and way oversized, but I only paid $3 for it so I decided to make it fit!
Originally posted by skinnypin View Postlooks good. Thats the bracket i thought it was. How does it set in? dont move around at all does it. Otherwise i like it. would have gone with a nicer cd player myself."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
It should just be there to hold up the stock cd player so not just the face holds it up.. I dont ever use these when i put in an aftermarket unit but i usually use the kit cause its just easier...1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
