amp is ran. sub is ran everytime i try to turn over ... nothing.. it kills all power... any suggestions?
sub not working...
definately a ground problem or you got a wire shorting out. check all the wires again and make sure none are touching each other or metal(frame). it would help to know if your car ran fine before hooking all of this up(like said above ^^^). if so then something you got wired together is not right. keep double checking everything.
Or possibly a bad amp?
^ That's what I was thinking. The amp may be shorted. I would unhook just the amp power cables (at the amp) and see if the problem goes away. If not then check the wires as someone has already mentioned. They may be shorted under the carpet.
One quick question, does the system play before you try to start the car? I.E. amp and sub produce sound?Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Originally posted by bebandit View PostOne quick question, does the system play before you try to start the car? I.E. amp and sub produce sound?
didnt think of that before either^^^^. Could be something going on inside the amp. wires loose inside of it. if you know what your doing and being careful, take the amp apart and look at all the wires inside of it. no wires should be running together. they should be soldered in seperately.
also as stated above^^. the speaker wires could be pinched together. mine was doing this and it made my radio not work but it didnt make my car not start. so not really sure if that is it. i still think its got something to do with the power cord and ground. any way that you accidentally crossed them? i can see that being the problem.
