Ok well I just hooked up this JVC deck in my car and it got power to the deck and power to the speakers and there was no sound to the speakers so I took it out and jumped the power to the battery an hooked up a speaker and it worked fine so I put it back in and it worked. Well I got to my house and it wouldn't pump out sound again but eventually I figured it out and went I held the brake pedal when I turned the car on it would pump out sound. But when I do that and it works and turn the headlights on it won't work again so I'm confused as hell.
Wierd stereo problem
Run new wires to all speakers and power / ground. Eliminate the problem by eliminating anything that could be the problem...
My Fleet:
