i'm looking at buying a 92 festiva,but it doesn't have a radio in it from the factory,how difficult is it to put a stereo and speakers in it,is all the wiring there?
difficulty????
My guess would be probably. In my experience most of the wiring is in most of the cars, things like power mirrors and rear wipers, etc., whether or not the car came equipped with those options. Never owned one without a radio, but I've had a couple that came without rear speakers, however the wiring harness was right there behind the trim panel at the spot for the speakers. If possible just pull the trim plate where the radio should be, and see if there's a harness back there. I think its two four wire plugs and a two or three wire one. Also, don't forget you'll need an antenna
No festiva for me ATM...
Installing an antenna: http://www.fordfestiva.com/forums/sh...hlight=antenna
Speaker wire is simple to run if you don't have any.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
