If you want the CB to go further in the slot, you can unscrew the case, cut off the plug on the antenna cord, and solder the wires directly to the footprint of the connector. You can then cut it about 4" away from the CB and add a breakaway plug, so you can still route the wire before plugging it in. I could do this for you if you lived closer. I know a guy in SC who might be able to, though.
Edit- Looked at pics. You can just solder it if its routed.
