Hey guys! I had been reading through the forum and did a few searches but couldn't find any pictures or information on how to mount 5 1/4" speakers in the back. For reference, these are the speakers I have and want to install. http://www.pioneerelectronics.com/PU...ries/TS-A1374R
I found a post by Monsoon stating if you break off the tabs and drill new holes to make a 4" hole pattern it works, but that was for a different model of pioneers and simply put, I cannot see that working on my setup since the trim around the speaker is so narrow.
What I was thinking of was cutting the speaker grill out in the rear with a dremel, so a hole (in the shape of a circle) replaces it, and then just sit the speakers in the hole and worry about securing them later (although it's very unlikely they would bounce out, if it goes according to plan)
It is hard to understand unless you actually see what I mean, so tomorrow I will try to get a picture and highlight what I want to remove.
If this was too long to read, then simply suggest ideas on how to mount the speakers. Thanks!
