Figured i would post this up.
I finally got sick of my trunk space being taken up by a subwoofer and having to move it around, only problem was i wanted plenty of bass... So i decided to do something about it. I ordered this http://www.rockfordfosgate.com/produ...tails/p3sd4-10 and built a box exact to rockford fosgates specs. I used the minimum cubic volume they had in the specs and this speaker is a dual voice coil so it has two speaker inputs, now my amp puts out 600 watts rms @ 2ohms so i ordered the 4ohm version and connected the dual voice coils in parallel to drop it to 2ohm. All i can say is wow! i have more then enough bass in fact only have the amp gain at half, and it shakes my mirror so much you cant see out of it, And guess what it maybe takes up a 1/4 of my trunk space if that, and its downfiring so that you can place stuff on top without having to move the speaker around at all. Here is some pics.
If any body is interested i can give you all the measurements and directions on how to build. I spent around 30.00 on the material to build the box, used 1/2" mdf, silicone, and screws.
