will 5 1/2 inch round speakers work in the stock Festiva rear speaker location without modification? I know the factory size is 5 1/4 rounds, but I got a pair of 5 1/2 inch from my old aspire I wanna try and use... also will Alpine Type-S 4 inch speakers (http://www.cartoys.com/car-audio/spe...-range/sps-410) work in the factory location or would the tweeter stick out too far?
rear speakers....
rear speakers....
Last edited by old yellow; 02-03-2014, 01:15 AM.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
Tags: None
I know about the front..... will 5 1/2 inch speakers work in the stock rear location without modification?Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Stock size for the rear is also 4" so I believe that modifications will have to made to fit in the larger speakers.Ian
well the local audio shop confirmed that the stock location for speakers in the rear is 5 1/4 rounds, could I use a 5 1/2 round speaker in the 5 1/4 round speaker hole without modification?Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
I can confirm also that the stock location has an opening for a 5 1/4" speaker, BUT it has mounted into it a 4" speaker from the factory. So a 5 1/4 " speaker WILL require modification, end of story. Trust me.
The link above is wrong. Sorry. I am not trying to be a troll here by any means. I have installed audio systems for over 24 yrs now and have done so in many Festivas too.
1. The rear location will accept many 4' speakers without modification.
2. The 4" speakers that have a large tweeter mounted to it will require a little bit of mods.
3. To put a 5 1/4" speaker into the rear Factory Festiva speaker location will require some pretty decent amounts of modding to fit properly, but can be done easily if you have toe fabricating skills.
4. If you want it to look stock and be a pretty straight forward job. stick wit a good quality 4" speaker.Last edited by Gomez; 02-03-2014, 08:50 PM.-Bryant
I wouldnt go so far as "decent amounts of modding to fit properly". I made a set of simple mounting rings waterjetted out of Alum. which could be screwed to the OE 4" locations and had additional OD to allow the mounting of the 5.5" spacing. Only trick was a pretty significant flat area to fit into the wall side of the factory speaker enclosure.
They spaced down those Dual cone speakers enough that the Tweeter section didnt impact the grill/ribbing.Last edited by needragr; 03-08-2016, 12:21 PM.
Agree with the above, except for one thing. You will find it far easier to fabricate with fingers rather than toes, due to their being longer (on most of us anyway) and have far greater dexterity.Originally posted by Gomez View PostI can confirm also that the stock location has an opening for a 5 1/4" speaker, BUT it has mounted into it a 4" speaker from the factory. So a 5 1/4 " speaker WILL require modification, end of story. Trust me.
Gomez, think how much time you would have saved if you had used fingers for all your work! BTW did you use your toes for the welding work when fabbing up short shifters? If so, there might be a market for heat-resistant toe socks.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
