6 1/2's in the doors
  • 6 1/2's in the doors
    I've seen some festivas with 6.5's in the doors. Does anyone know the max mounting depth in the doors.
    Red 89LX 5speed
    Aqua 90L 5speed
    Blue 97 Aspire Auto
    i don't know, but it wouldn't be hard to pull the door panel off and measure
      the door panel has 4 screws and those little snap rings. i have to pull mine off whenever i lock my door. lol
      89 L, hopefully returning from the dead soon with a little more power... :twisted:
      http://www.fordfestiva.com/forums/sh...77-my-89-build
        where the pocket is behide the panel there is a hole about 5 1/2, wit the window down u hav 1 1/2 ins of space, with the right size and stuff u can put a 6 1/2 wit space, iam going to try it soon,
          I put 6.5's in my doors and all I needed to do was place them over the door panel I made. They are a pretty high quality JBL and have a big magnet. You have to watch out with the wiring though and make sure the window clears it. Other than that the install was no problem and sounds great amplified with separate tweeters higher in the door!
          Soon to be BP'ed 92' white Festy from Worcester
          http://www.cardomain.com/ride/2669252/1
            i have 2 12'inch C1 preccision Power Subs, Rockford Amp, panosonic deck, and Led lights, and 2 speakers in my door, using
            1inch wood same size as my speaker to make it fit my speaker without hitting the door, i had to cut whole in my inside door tho
              I removed my door pocket and my 6 1/2" Pioneer Splits fit in there fine
                im thinking of putting some 6.5s in my doors as well. i made a dash to go in the back to hide my sound system from prying eyes and out some 6.5s in it. for the ones in the doors ill probly just run wires through to harness in the doors to and splice into the wiring for the dash speakers since my radio doesnt have an extra set of wires for the front
                  do you have to remove the door pockets to make 6.5s fit?
                  Mike, AKA the sasquatch
                    My 5 1/4" fit with the pockets in place. I needed a spacer to clear the glass though.
                    89SX funtop! Fully loaded!
                    RIP 90LX
                      should just need a shallow speaker
                      93-1.6l
                      f.s.- fms bodykit.
