hay guys, does anyone know what the timing should be set to on a FI B6, thanks
b6 timing
as i've read off of Mitchel on Demand, 6 BTDC is correct....Trees aren't kind to me...
Either will work; the question is whether you want to pay for Regular, Mid-grade or Premium, to prevent knocking.Originally posted by funky technicianhum, soooooo :shock: LOL
Gradually increase the ignition timing and see what the motor is comfortable with on Regular gas; once it starts knocking, go back a little on timing. For more power, put a tank of Mid-grade in and do the same thing. Same with Premium.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
