We have the same holley-weber carb on our lemons car and figured it was just a redneck install. It looks like it bolts directly onto the manifold with no adapter, but we haven't had it off in a long time. Choke is wired open, jam a screwdriving in the linkage to keep it running for a minute or two and it's fine. Runs rich at idle and off the scale of my wideband O2 under throttle. We're replacing it after this race, most likely with an efi BP swap.
Found: Weber carb kit for 1988-89 Festiva (?)
^ wanna send that setup my way when you're done?Trees aren't kind to me...
Wow that would be great if it didn't even need an adaptor plate!Originally posted by oxbrain View PostWe have the same holley-weber carb on our lemons car and figured it was just a redneck install. It looks like it bolts directly onto the manifold with no adapter....90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I was wrong. I went looking for pictures and found a shot of the carb with an adapter plate visible below it.
According to my teammate, it's very poorly done, but could serve as a good template. It's a chunk of 1/4" aluminum that someone attacked with a dremel and a case of beer. Two studs pass through from the original carb mount, then two bolts with the heads ground flush hold the plate to the manifold, then two tapped holes for the carb to bolt to.
We'd be happy to pass it along when we're done with it. Any money we get from the sale increases our $500 limit.OX SMASH!!
Bump, just because. Some of the links don't work any more tho.
Weber Jetting Chart
The various 32/36 DGV types are basically set up for a 1.8 liter motor, so take that into account when jetting for a Festy.
DGEV is electric choke, DGAV is water choke, and DGV is manual choke.
Those who have experience setting up their Webers for B3s and B6s please chime in for the rest of us, to save some reinventing the wheel and lots of questions. What motor, what jets you used.Last edited by TominMO; 03-09-2015, 09:03 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
You can have one without an adapter plate. Just add a little welding, drilling and tapping.Originally posted by TominMO View PostWow that would be great if it didn't even need an adaptor plate!
You gonna race that thing?
I know that now. Five years and four months ago I didn't. But good to bring up anyway. Nice B6 carby mani there.Originally posted by Festy46 View PostYou can have one without an adapter plate. Just add a little welding, drilling and tapping.
http://www.jmflumber.com/xtrafiles/Carbconver6.jpg90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Do the stripes or flames increase the fuel economy or horsepower lolOriginally posted by TominMO View PostThanks for the input and picture. I think that a good machinist could even make up a one-piece adapter, with just the Festiva and Weber gaskets as templates. Does the carb say Holley-Weber? I think it's just a Weber. The only Holley-Webers I am familiar with are one-barrels, found on some old Subarus. 32/36 means it's a two-barrel carb, of course.
Good stock carbed motor, probably worth 10 more HP:
Weber 32/32 carb
FMS street cam
full FMS exhaust system
40,000-volt coil, such as Jeg's part #555-40105 (red, $19) or 555-40100 (chrome, $20); www.jegs.com; 800-345-4545
10% larger plug gap for more complete fuel burning
upgraded plug wires
advance ignition to the point that you need premium or at least mid-grade gas
racing stripes or flames
