hay guys, I was just wondering if theres a coil upgrade like blaster or what ever for a 93 festiva that now has a b6, and where do you buy it, the stock coil seems weak in mine
ignition coil upgrade namebrand
which one do I need, the one with the risistor or the model without? It says that the one with the risistor is for a points system, but I thought I herd someone on the forum mention that they didn't know what to do with the risistor, denoting they purchesed the one that came with it, should I get the risistor one or the one without it?
thanks :wink:
cool, I wonder if anyone else had problems with burning out there distributor without using the risistor, I read one post were a guy burnt out 2, then said he never had a problem after he installed it, so it knida makes me nervous, but I did notice there is a small risistor up beside the stock coil (small rectangle with 2 wires), wired back to the same wire bundle, is this stock equivelant of the risistor provided in the coil kit?
sorry, I ment he burnt out 2 distributors not useing the risistor, not 2 resistors, so I'm wondering if that small rectangle wired in next to the coil is the stock resistor or something else, if so maybe they mean to replace this with the supplied risistorOriginally posted by 25HorseplayResister's are cheap.
I kept mine and screwed it into the wirewall up where the wiper motor use to be. Just hook up the msd blaster 2 coil and fatter wire is the positive wire the other is the negitive...---------------------------------------------------
I just bought the blaster coil, the resistor is not needed in our cars. Buy it and connect the 2 wires. PM me if you buy one and I'll go out to the garage and see what wire goes where.
