I have a mildly modded B3 Aspire. Full exhaust system, and some intake work.
My stock clutch was burnt out from the car being hammerd for the last 2 years. This was replsced with an exedy HD clutch in july this year. Around april last year new CV joints and shafts were fitted because the stock ones were failing. When the mechanic changed the clutch it was noticed that there was shaft warpage and joint deteritation, caused by "excessively high and repated hard lunches". basicaaly he said that the shafts had triwsted becuase i launch the car off the lights at high RPM.
I managed to get the shafts replaced under warrenty after alot of bitching, even thou i broke them. My concer now is that these shafts are piss weak and that it wont be long before i break them again. Does any1 have any suggestions for a tranny + shaft combination that will see longer life then the stock shafts.
My car is driven hard on a daily basis, and is commonly lunched at high rpm. I didnt think that OEM spec shafts would be able to be warped to the point of failure by my driving style, on a not very powerful engine. Just wanting some opinions and options from you guys. I do plan for more poweful engine setup in the long run aswel.
Thanks guys
Thanks guys
