How do I remove the oil pan from my B6T engine? I've removed the 8-10 bolts on the bottom... The clutch and flywheel are both off... The only thing left on is a bracket that holds (what I would believe to be maybe something with A/C), but there are no bolts from that holding the pan on.
Do I need to remove the pulleys for the belts on the side (it'd be on the passenger side) where the alternator belt runs?
Or is it just posisble that it's stuck on and I need to beat it off? When I took the head off the block, it came right off without ANY problems... The oil pan doesn't want to cooperate.
