im swapping in the f series tranny out of an 89 mazda 323 into my aspire.anyone know of a good clutch to use?wat all cars will the clutch work out of?
what kind of clutch
What engine do you have? That will make a big difference. If you don't have a turbo on the motor, just use the stock clutch for that motor. IF you have a BP, get a clutch for a SOHC B8 protege. You can't use the BP clutch because the spline count is different. If you are using the F-series transmission, whichever clutch you choose has to be for a car that had an F-series transmission.The Festiva Store
Welcome to the official Advanced Clutch Technology website | Advanced Clutch Technology - Excellence in Performance. For unmatched quality, feel and durability, insist on ACT!
I have the 6 pad solid hub clutch in my car with the 89 323 tranny and the BP engine and it seems to work good. I haven't got a chance to put many miles on it but it hooks up hard and fast. If I were to change it out I would probably put the spring centered hub one on as it would be a little more forgiving for daily use.90 festiva BP/G25MR swap, spec v seats, aspire brakes, FMS springs, round headlight conversion with HID's, custom exhaust, fiberglass hood, and a whole lotta bodywork
BEFORE
AFTER
^^^ Your signature says you have a G-series tranny, but then you say you have an 89 323 tranny. The 89 NA 323 had an F-series tranny. The 89 323 GT had a G-series tranny.
aspireguy, If you use an F-series tranny, you must use an F-series flywheel and clutch. These can be found in:
4-cyl MX-3
B8 proteges
323s any year
Capri non turbo
Basically any B-series Mazda cars other than festivas, aspires, 323 GT, GTX, escort GT, capri turbo, and proteges with the BP. I don't know what is hooked to the proteges with the 1.5.The Festiva Store
There were proteges with BPs which had G-series transmissions. There are also proteges with SOHC 1.8s that have F-series transmissions. For anyone else reading this, G-series trannies have 22 tooth input splines, while F-series are 20 tooth. The protege with the BP was an LX, the protege with the SOHC 1.8 was the DX. The SOHC protege has 7 7/8 inch clutch, while the mx-3 has a 7 1/2 inch clutch. The BP protege clutch is 8 7/8 inches. The protege with the 1.5 also uses the F-series tranny. The AWD protege uses a G-series AWD transmission, so this clutch will not work either.The Festiva Store
[quote="nonamekid"]^^^ Your signature says you have a G-series tranny, but then you say you have an 89 323 tranny. The 89 NA 323 had an F-series tranny. The 89 323 GT had a G-series tranny.
[quote]
my bad, didn't even think about the f vs g series when I posted that... Mine was from a 323 gt and is the g series. Regardless, I would suggest a spring centered hub for whatever clutch you choose.90 festiva BP/G25MR swap, spec v seats, aspire brakes, FMS springs, round headlight conversion with HID's, custom exhaust, fiberglass hood, and a whole lotta bodywork
BEFORE
AFTER
correct. typically though the bigger clutch offers more holding power, but it is not that big of a deal.Originally posted by aspireguy95so it dont mater if its 7 7/8 inch or 7 1/2inch?
as for what type of clutch to get, I would go with LittleHoe's suggestion.The Festiva Store
