Whiskey Tango is THIS clutch and flywheel?
  • Whiskey Tango is THIS clutch and flywheel?
    I was rooting through the parts on hand (summer parts= "Summer still good...") and found a clutch and flywheel that must be for the Capri B6T engine and trans -
    But it looks nothing like what's in the book...
    On left is what I believe is a stock B3 Festiva Flywheel
    I've never seen one like this before
    My Turbo machine has a B3 trans in it, and the Capri trans (on the floor of the shop at the mo) is about to be looked over real close. Meanwhile I have a bad clutch in a B6T Festiva with a trans I ought to stick in my white car
    I sent for a B6T clutch kit before double checking what was in there
    I do now have graved into my brain the knowlege that a B6T trans has a 15/16ths inch input shaft with 22 splines, and stock Festiva B3 trans have a 3/4 inch shaft, and 18 splines
    B6 & B6T trannies have a tin cover on the drivers side end also
    The disc that was between them doesn't even have any wear marks on it - it's still rough from the factory.
    I've got no clue Guys and Dolls...
    * member Studebaker is helping me sort out a bag of snakes between the two cars I have left
      The new clutch fits the funky looking flywheel, so I guess it must be so...
        It sure looks like my B6T flywheel, and if it fits the clutch you bought for a B6T, that pretty much nails it.
        Thricetiva replaced Icetiva as the new ride
        Icetiva-3-race-car-build
