This is a guide for installing a Honda adjustable shot shifter into your Festiva using the Honda OEM shift lever ball seat and dust boot for a true fit!
This shifter not only looks great but is very functional.
Credit for shift lever goes to Will Samet!
Shift lever ball seat and dust boot was my little experiment and it worked!
Cost for me was $65 all bought from eBay.
PARTS NEEDED
- Shifter lever ball seat # 54110-sh3-003
- Dust seal # 54115-sh3-000
- Adjustable civic short shifter ( or any Honda short shifter of your choice )
- Shift Knob ( 10x1.5 thread)
PHOTOS OF PARTS
STEPS
Remove factory shift lever.
Start by modifying the dust boot area that fits around the ball seat. It must be ground down almost paper thin to supply enough clearance to slide down into the assembly.
I also cut the top ring off as it bulged out as i tried to press the ball seat and dust boot into the assembly and caused it not to go down any farther.
If you can get it all thin enough this may not be required.
I found it easiest to install the ball seat and bushing onto the shifter to add support and used a bench grinder to slowly remove material until i was able to install it.
It took a few times to get it right and it is a very tight fit. Use grease to help it slide in better.
MAKE SURE YOU ADJUST THE BALL ON THE SHIFTER LIKE YOU WANT IT BEFORE YOU INSTALL IT!
I screwed mine all the way up so my shifts are as short as possible.
This is what is looks like from the bottom once its all the way in
I used the embedded metal part of the factory dust boot as a washer of sorts and placed it down over top after it was all in place
You then reinstall the preload spring.
Use some washers to take up the gap in the linkage. Tighten it down and you done!
PARTS NEEDED
PHOTOS OF PARTS
STEPS
