Can you use axle shafts from Aspire and will they bolt in to a Festiva.I got both a Festiva and an Aspire complete from the junkyard today.
Just bought Festiva,Aspire & volks rims
Tks , I am going to use the Aspire Manual and put it in the Festy, hopefully some of the Clutch pedal stuff can be used to change the Auto Fetsy to the Manual
TksAspires and Sways all around, Miata B6 installed, KYB G2Rs just installed in front. Wish for coil overs someday.
The aspire is wider in the front than the festiva, and uses longer axles, so you can not use aspire axles in a festiva and vice versa.The Festiva Store
