Just bought Festiva,Aspire & volks rims
  • Just bought Festiva,Aspire & volks rims
    Can you use axle shafts from Aspire and will they bolt in to a Festiva.I got both a Festiva and an Aspire complete from the junkyard today.
    Aspires and Sways all around, Miata B6 installed, KYB G2Rs just installed in front. Wish for coil overs someday.
    Well the automatic axles only fit in a auto transmission, but I believe the hubs are all the same for the axles at least. Manual to Manual, Auto to Auto. Hope that helps
      Tks , I am going to use the Aspire Manual and put it in the Festy, hopefully some of the Clutch pedal stuff can be used to change the Auto Fetsy to the Manual
      Tks
        The aspire is wider in the front than the festiva, and uses longer axles, so you can not use aspire axles in a festiva and vice versa.
        The Festiva Store
