can you make a g25mr out of a g5mr??? I think one is hydrolic and the other is cable can a person make this work?????
g5mr modify?????
You can convert the festiva to hydraulic.
hey kemp if you find that info let me know i would like to conver that kia trans to cable to make life easier if i can if not i will just make it hyrdaulic, also on a side note if usine a G25 trans on a BP the oil pan bolts wont line up and if useing a b6,b6de, b6t on a G5mr the bolts wolt like up with the oil pan either, they say its not a big deal though
What the heck are you talking about?Originally posted by Hot_Wheels View Poston a side note if usine a G25 trans on a BP the oil pan bolts wont line up and if useing a b6,b6de, b6t on a G5mr the bolts wolt like up with the oil pan either
I've had a g25mr & g5mr both bolted up to a bp.
Poverty produces creativity
That is not the difference between the two. The G25MR is the second generation of the G5MR (also known as G15MR). There are G5MRs that are hydraulic. Look in the sticky. And I know I just answered this question in a topic in the general section, so I won't repeat it.Originally posted by wcbarker View Postcan you make a g25mr out of a g5mr??? I think one is hydrolic and the other is cable can a person make this work?????
i believe there were 2 of us that did it first round, me and another guy who sold his car. both of us did a hydraulic BP escort swap. mine is out of a 91 egt with the g5mr trans. converting to hydraulic isnt tough, just open up the hole where the cable went through, drill a hole for the extra bolt used by the master clutch cyl. then make a mounting bracket for the pushrod on your clutch pedal.
easy as that. been runnin my bp festy with the hydraulic clutch for prolly around 3 years now? maybe 4?
i can try to dig up some old pics if you need them.1992 Festiva... BP-T, Escort G5MR, no crossmember, aspire brakes, Megasquirt, Toyota COP's, coilovers and 6 puck SPEC clutch!
i did the same thing. only drawback is the pedal effort because of the geometry. stroke is really short though, makes for awesome speed shiftsNeil
Jesus loves me. This I know.
93 L track prep in progress
88? Parts car-sold
86 b2000- pisses of HOA-sold
here's fastiva55's page. it has some info on the hydraulic clutch install
