Has anyone tried trimming off the VAF-to-airbox mounting flange from a VAF to make it physically smaller, fabricating a bracket then use a K&N style filter?  I hate that huge assembly blocking access to the belts, timing marks, etc.
Cold Air intake VAF help!
Check this, might help.Originally posted by CharlieZ View PostHas anyone tried trimming off the VAF-to-airbox mounting flange from a VAF to make it physically smaller, fabricating a bracket then use a K&N style filter? I hate that huge assembly blocking access to the belts, timing marks, etc.
'93 BP-T 57trim TO4E - Coilovers - 13x7 steelies - 175/60 - 48k mi
well i have been having lots of trouble with my idle... car viberating bad.. and i think its all because of the mouting position of the VAF..(god, i hate this huge thing)
Anyway, i need some input on how i can mount it to the spicified position in the pic?
bringing up an old thread but had a questionOriginally posted by goodbabbu View Postwell i have been having lots of trouble with my idle... car viberating bad.. and i think its all because of the mouting position of the VAF..(god, i hate this huge thing)
Could you mount the VAF flat then do a 90* turn down off the VAF and into the fender and put a filter inside the fenderwell? Or does it need to be right next to it as in no tube btw the VAF and filter?
I don't think it would matter as long as the VAF is level and there seems to be some differences as to if that is an issue.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
yeah as long as its level you should be fine. They make a 3" adapter for the inlet side of the VAF, so you should be able to plumb it up from there. You could always see if you can mount the VAF to the throttle body then be free to do what you please with the intake...
Poverty produces creativity
Did it makes difference in power with the metal tubing?Originally posted by goodbabbu View Postwell i have been having lots of trouble with my idle... car viberating bad.. and i think its all because of the mouting position of the VAF..(god, i hate this huge thing)
:festiva: 1995 Kia Pride, 1.3 EFI, manual. :fred:
Your spring might have been weak, its adjustable.Originally posted by Biglay5150 View PostI tried that when I did my swap and it wouldnt work for me. I couldnt get the motor to rev past 3500rpm. I mounted it level. I dont know why it wouldnt work for me if it works for you guys. I just assumed it needed to be level.
Zippy ties goodbabbu, zippy ties.Originally posted by goodbabbu View Postcan i use commercial grade cable ties... do you guys think taht would hold the VAF... i am just throwing ideas out!
I took the stiva out today for the first time in 2 weeks. Just got back from oc. Im about to go back here in a few min but before I do I'm going to unhook the dp from the turbo and use the big zippy ties Greg gave me to hold the dp up so I don't have to take off the whole exhaust.
No.Originally posted by lancerevo View PostDid it makes difference in power with the metal tubing?
I had my vaf mounted vertical in my first car before I went turbo. I didn't have to adjust the spring or anything, it ran fine. If it stalls out or idles rough you can try tightening it a click or 2 or 3.Last edited by resuwrecked; 05-21-2010, 06:38 PM.
