im gonna go turbo now... lol... anyways i have a lead on a set of wiesco b6t pistons, i know they fit but im wondering if the crank will fit too? also whats stronger? bp or b6t rods? im thinking b6t but not to sure....
b6t crank in a b6 block?
Mike, AKA the sasquatch
1990 LX, bp+T/g25mr, 9psi dynoed at 194HP, turbonetics t3/to4e 57trim, haltech E6X standalone, 550cc injectors, turbosmart wastegate, synapse BOV, walbro 255 fuel pump, aeromotive FPR, AEM wideband, 3 inch exhaust, huge FMIC, 9LB flywheel, 6 puck clutch and way more parts that im forgetting i installed lol...Tags: None
Turbo rods, they handle the extra boost from the turbo.Chuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
but i have read that the bp rods can handel like 300hp but once you get past 200hp on the b6t rods its getting risky....Originally posted by hotfordcat View PostTurbo rods, they handle the extra boost from the turbo.
^ wrong
The B6t are "stronger" than the Bp rods. Granted the bp rods are also in the BPT's. The only stock option for stronger than the B6T rods is the BPD GTR rods...
Also depends on the price point your working towards. Decent aftermarket miata rods surpass even the GTR rods & weigh less to boot.
Poverty produces creativity
all b6 botom end parts will swap save for the pistons (bore remains the same, valve reliefs can change).
run the lighter of the two rods, you won't break them unless you're tune is off.Trees aren't kind to me...
thanks for the info guys
 cant wait to get it all working
