twin carb conversion
  • #76
    Originally posted by bravekozak View Post
    Found this link for B6 specs.
    Huge amount of information there for a carby guy like me. I may learn something about FI one of these days.
    Thanks,
    Jack Byrd,
    1991 Capri
    1988 Festiva LX, 240K
    1970 Chev C10
    1977 Airstream Argosy MH
    • #77
      I have a couple of lengths of -6 Aeroquip hose. I would only need the banjo fittings for my Mikuni twin carbs. The fittings are M12 X 1.25. I went online to buy a pair, but now I am recovering in bed, with an oxygen mask, after suffering an anxiety attack.
      Who makes up these ridiculous prices? I will have to search for some used ones.
      Another alternative is to bend and flare some -6 stainless tubing.
      Polished hard lines are just as pretty.
      I want to also mount my chromed Carter four ceramic cone fuel filter.
      • #78
        Here is a video of how to flare hard fuel lines for use with AN adapters.
        Earl's tube nuts and sleeves (see page 66) were used. The only difference is to use annealed stainless tube that won't crack while flaring. I will pick up a length the next time I visit Classic Tube.
        I only want some sexy polished stainless tubing from the bypass regulator on the valve cover to the carbies. Black rubber is ugly.
        • #79
          Hey, hey!
          I believe I have found something in my price range.
          They are only for quarter inch tubing! But they should do.
          I just need a -4,-4,-6 tee.
          Maybe it would be a lot easier to have everything at -6.
          • #80
            Short quick and sweet!
            I really did enjoy reading that.
            Is there group therapy somewhere ?
            • #81
              I had never seen that colortune thing before, that sure would come in handy on my vintage motorcycles. Thanks for sharing that!
              • #82
                You're going to have the sexist Festiva in the universe.
                Jack Byrd,
                1991 Capri
                1970 Chev C10
                • #83
                  I must be in the minority that doesn't understand AN fittings. They are so expensive for what they do. And bulky. Give me a plain old "ugly" brass fitting any day.
                  • #84
                    Army Navy (AN) fittings are 37 degree which is said to provide the best seal to prevent leaks (as opposed to 45 degree brass fittings). I just like the blue and red anodizing.
                    • #85
                      ^^^ You are correct! 37* is what they use on aircraft!
                      Dan
