anybody ever heard of a point distributor being available in a festiva? or anyone tried making one? i've had so much trouble with the Ignition control modules. seems like the old simple style would be so nice.
distributor with points?
me too I loved the old points system and they worked like magic with a transistor assist and I miss them, with the transistor assist the only thing that would wear out was the nylon cam"all I ask is the chance to prove that money won't make me happy":simon:
Not me...I don't miss setting dwell or timing one bit.
I worked on a '75 302 a couple of months ago...conneting a dwell meter.....connecting a tach...setting the vacuum...adjust the idle mixture....repeat....repeat....adjust the timing...tighten the distributor...double check the timing...start all over...I love electronic ignition.Joe Lutz
The SKATE ..... 1992L 5spd
wuss! :pTrees aren't kind to me...
After 2 VW's a 71 Nova you can keep your old school. And yes that does make me a wuss.Originally posted by jglutz View PostNot me...I don't miss setting dwell or timing one bit.
I worked on a '75 302 a couple of months ago...conneting a dwell meter.....connecting a tach...setting the vacuum...adjust the idle mixture....repeat....repeat....adjust the timing...tighten the distributor...double check the timing...start all over...I love electronic ignition.Going old school...
Based on the electrical system in my old house, I am devising a knob & tube ignition for those who want to be Reallly old school.
yep, keep those points, I'll stick with the newer stuff. I'm even getting an electronic module for the dizzy in my '69 Fastback VW.
I must have reset the amazing jumping dwell half a dozen times on the 73 (too cheap to replace the dizzy) I just jumped straight to the igniter for the 71 Super/ My buddys nova was actually a breeze, had this niffty little door on the capGoing old school...
New stuff here too.
Every car that I ever owned, if it had points, they were leaving first.Festiva: Because even my dog can build a Honda.
Oh I forgot....take the distributor out and clean the centrifigal weights....put the distributor back in....skip a tooth....idles great....cann't accelerate....start again.Joe Lutz
I'll stick with electronic too. I put a Crane Cams ignition system in my '89 after my 2nd ignitor went bad and it seems to be indestructible. Ebay - $20.00. Easy to install but the wire that adjusts the timing down when it idles isn't there. Doesn't seem to make any difference and it gets 40 MPG in the city.
