I'm in the process of dismantling both my B3 engines. I wanna clean up the heads, blocks, pistons, and so on. I'm just gonna keep it all stored for a while before I can start throwing money at it. What would you suggest for cleaning?
Cleaning engine components
Machine Shop Hot and Cold tanks. If you store them for a long period I would coat the machined surfaces with Vasoline.Chuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
even if there stored indoors its best to coat them cause any moisture on bare metal will rust
After they're cleaned, spray them all over with WD-40 (or rub with Vasoline), place them in heavy duty trash bags, then get your vacuum out and vacuum seal them.Festiva: Because even my dog can build a Honda.
get them hot tanked and spray with wd-40. then stick in a bag and vacuum seal it.... so what they said ^^^ lol....
Mike, AKA the sasquatch
yes. it shouldnt cost that much... i got my block, head, pistons, rods, crank, VC, OP and the thing inside the oil pan all done for 25 bucks... but i got it done all in one shot and i heard that was a good deal on that... try phoning around to machine shops and ask how much it will be to hot tank what ever you need done...Originally posted by thered56 View PostSo I should hot tank them before storing them? What's that cost?Last edited by sasquatch; 07-24-2009, 03:49 AM.
Oh wow, I just heard machine shop and thought it'd cost a bit more I guess. haha I suppose I can afford that! Thanks a lot guys!Originally posted by sasquatch View Postyes. it shouldnt cost that much... i got my block, head, pistons, rods, crank, VC, OP and the thing inside the oil pan all done for 25 bucks... but i got it done all in one shot and i heard that was a good deal on that... try phoning around to machine shops and ask how much it will be to hot tank what ever you need done...
Now, what are the advantages to each of your suggestions for coating the parts? Vasoline vs graphite based paint vs WD-40? I like the sound of Vasoline, but I don't know which would be better, or if it makes much of a difference.
