ok the arow is the actuator arm, you need to add a spring from your arm to the wastegate pulling or pushing them together which ever way you WG moves... it will make the wastegate think its under a 4lb load all the time... so when it reaches 5lbs it thinks its at 9lbs and it opens up... if you get a small hand air pump and a air pressure gauge you can adjust the pressure it opens up.
