What engine came in the Mx3? Is the 1.6 a B series engine? If so, i can get a DOHC 1.6 16 valve for pretty cheap at another wrecking yard, but this yard sucks lol, all there stuffs stocked, you cant walk in, you cant pull anything yourself and if its not pulled you have to pay extra...i hope the motors put of the car...
MX3 Engine
92-93 Mazda MX3 engine (B6-ME?) - 1.6 liter SOHC 16v. Puts out 88hp
94-95 Mazda MX3 engine (B6-DE) - 1.6 liter DOHC 16v. Same engine as the Capri, but puts out 105hp.
They both are b series and will fit in the festiva.
matt
No MX-3's came with bp's and the b6 isn't a b6de its a b6ze its different from the capris motor by a long shot. You can trust me on this since wil has a mx-3 and he has done a lot of research on that car and well the first engine that we swapped into the car was a b6de from the Capri and the one in there now is from a MX-3. Oh yeah and its a pita to wire the car with the dohc engine. Mine wouldn't run correctly so I got a mechanic to do what I couldn't do which was get it running good. As for the tranny its bolted right up to the engine in the MX-3 which is why you can use a MX-3 flywheel which is light weight much more than the festiva and an ACT clutch which are amazing.the blue b6-ze oh yeah!!
