Everyone knows the 89' Auto's are the fastest autos right?  I guess because they have vacuum advance or something, doesnt really make sense to me, but anyways, I once had an idea, but after more thinking, will it work?  My idea is to take and swap in a replacement engine into my 89' auto, to make work again, probably just a B3, nothing fancy.  My question is, I was also thinking I would like to swap a 5-spd into it.  Would I be able to keep the 89' EFI system, or would I have to switch to a 90-93 EFI system, reason being the 89' 5-spd computers are for a carbed setup, and I dont think they have a different computer for autos than manuals, so my 89' auto computer wont work if I try to install a 5-spd, will it?
89' Auto to 5-speed manual
No one wants to give you any "thoughts"....you'll just neglect it and run it out of oil again so what's the point of a swap??---------------------------------------------------
take a hike and visit the arena buddy, I left you a message, all I really want was to know is if this is possible1997 Ford Aspire, MTX, Teal, B3E - "Trusty"
1997 Ford Aspire, MTX, Red, B3E - "Eggy" (RIP)
1989 Ford Festiva LX, ATX, Maroon, B3E - "TBK" (RIP)
1991 Ford Festiva GL, ATX, Red, B3E - "Festiva GT" (RIP)
My thoughts are, given your rant in the Arena, to go with WES's assessment.
I will provide you one piece of advice, we have PM's use them instead of taking your issue public, or not so public via the Arena.
You are ranting on a long time, knowledgeable, and mechanically capable member here.
Do you really want to make an enemy of him and those of us who consider him a friend?'93 Blue 5spd 230K(down for clutch and overall maintanence)
then WES should of done the same,
kept his comments to himself, instead of the useless crap above
just remember, WES made this comment, just to be spiteful in the first place and since he did it in the public eye.
I don't see why he can't take this argument to the arena
unless Pu241 has a problem with pwgus too??????????
I am the original
Gus, my GUESS is that the '89 ATX ECU will run the 5 speed FI swap just fine. There are no computer controls for the transaxle to worry about, so the only thing the '89 ATX ECU may be "different" on is running the specific '89 FI distributor. It's possible the ECU doesn't even differentiate between distributors, so that may not apply.
ahhh, thats more helpfull, very interesting and much appreciated. I was thinking the computer had an input for like the clutch on off switch on a manual and the neutral safety switch on an auto, but maybe not. how different is the 89 distributor? I forget. If I ever happened to make this work, would this become the fastest stock manual setup available, since isnt the 89 EFI system faster than the other EFI systems?Last edited by pwgus; 10-26-2009, 09:34 AM.1997 Ford Aspire, MTX, Teal, B3E - "Trusty"
I think the '89 ATX distributor just has a greater timing advance adjustment.
Ive got a swapped car, a B6D out of a 93 Capri XR2, with an auto tranny Capri ECU, but on a Festy 5-speed. No real issues.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
hmm, interesting, what about the clutch switch and stuff?Last edited by pwgus; 10-26-2009, 10:50 AM.1997 Ford Aspire, MTX, Teal, B3E - "Trusty"
ok, sounds good I guess than, wow, I wouldnt have thought it would be that easy1997 Ford Aspire, MTX, Teal, B3E - "Trusty"
