I was wondering if the B3 head has a smaller combustion chamber than a b6 head :scratch: ....I know that the b3 head might not flow as well but i figured that porting the head and having bigger valves installed along with something like the fms racing camshaft or something like that might pick the flow back up and produce more power with the higher compression......thats only if the combustion chamber is smaller on the b3 head than the b6......
Heads
Heads
(90 festiva lx STOCK)
(Transmission is going)
(b6 swap maybe)
(Working on interior-Navy Blue paint on the dash)
MY OTHER CAR......
1986 cutlass supreme
Engine: Rebuilt SS 305 crane cam,weiand,3 angle valve job/port and polish,.030 over..
Trans: Rebuilt Th-350 trans-go shift kit
Rear axle: Monte ss 10 bolt 3.73 Limited slip
Tags: None
The b6 has a larger chamber. The Festiva intake valve is shrouded about 1/4 of the way around, maybe to promote swirl in the chamber. Since the B6 has a larger intake valve the chamber had to be opened up.
This is the b6 chamber.
No spitters were I work, you swallow it all. The Company feels if you already have it in your mouth why waste it.
exactly.Originally posted by NovaSS View PostThe Festiva intake valve is shrouded about 1/4 of the way around, maybe to promote swirl in the chamber.
and, by opening up the chamber in the B3 head for the larger valve, you virtually end up with the same chamber volume as the B6 head.Jim DeAngelis
Hmmmm....could this be SARCASM?!?!?Originally posted by gorgonheimer View PostWow you guys are smart.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
easy guys, no flames.Trees aren't kind to me...
no sarcasm. they are talking about fluid dynamics or whatever, thats like genius type stuff. i wish i new all that stuff. just when i think i have enough gray matter i come across these guys.Neil
Jesus loves me. This I know.
93 L track prep in progress
88? Parts car-sold
86 b2000- pisses of HOA-sold
nah, it's EASY! just know that you're better off slapping on a B6 head that has had the exhaust runner shelf removed and decked .020".Trees aren't kind to me...
Just kiddin' around. Probably shoulda put a smiley at the end. I figured he knew them and was just giving them some jazz.Originally posted by FestYboy View Posteasy guys, no flames.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
are there any aftermarket heads or dome pistons that are for the b6....I know that if you deck a head .010 it will only bring the compression up 1 point thats just a rule of thumb my teacher told me.... for example: 9.1:1 after a .010 deck would only bump the compression to 9.2:1....plus if i ever decide to do rebuild and need to deck the head because its warped i want to make sure the deck of the head is thick enough to keep the head from warping again....oh btw i was thinking of doing a b8 swap but changed it to a b6 swap to make my girlfriend happy she thinks i should try to keep it close to stock i have one toy already that she doesnt like.........(90 festiva lx STOCK)
(b6 swap maybe)
MY OTHER CAR......
The intake port doesnt look too bad, the exhaust port has the strangest shape, a 90 degree turn that has to flow like crap. I would round out the floor a little, clean up the seats ( blend job) and leave it at that.Originally posted by gorgonheimer View Postwhat about head porting a bp? any tips or tricks?
As for decking a (wrapped) head. What works on a OHV doesnt always work on a OHC head. If you want to pump up the CR on a good head okay. A wrapped head not only screws up the gasket surface but also warps the cam journal alignment. Not worth the money to correct on a b3/ b6 head far as Im concerned.Last edited by NovaSS; 10-30-2009, 12:39 AM.money pit
do the B8 swap, that'll afford you the option of using high comp pistons from a miata. and that "rule of thumb" doesn't apply to smaller engines.Originally posted by (90festivalx) View Postare there any aftermarket heads or dome pistons that are for the b6....I know that if you deck a head .010 it will only bring the compression up 1 point thats just a rule of thumb my teacher told me.... for example: 9.1:1 after a .010 deck would only bump the compression to 9.2:1....plus if i ever decide to do rebuild and need to deck the head because its warped i want to make sure the deck of the head is thick enough to keep the head from warping again....oh btw i was thinking of doing a b8 swap but changed it to a b6 swap to make my girlfriend happy she thinks i should try to keep it close to stock i have one toy already that she doesnt like.........Trees aren't kind to me...
sounds like somebody is jealousOriginally posted by (90festivalx) View Postare there any aftermarket heads or dome pistons that are for the b6....I know that if you deck a head .010 it will only bring the compression up 1 point thats just a rule of thumb my teacher told me.... for example: 9.1:1 after a .010 deck would only bump the compression to 9.2:1....plus if i ever decide to do rebuild and need to deck the head because its warped i want to make sure the deck of the head is thick enough to keep the head from warping again....oh btw i was thinking of doing a b8 swap but changed it to a b6 swap to make my girlfriend happy she thinks i should try to keep it close to stock i have one toy already that she doesnt like.........
Neil
88? Parts car-sold
