b3 header & cai pictures
  • #76
    Originally posted by mattdickmeyer View Post
    if you look closely youll notice the dowel pin location , it has 4 degrees of advance
    OK just asking it seems to be the in thing to have.
    Is the $150 + shipping for the do it your self or the ones you built?
    • #77
      weld your self 150.0 finished 250.0
      PROPOGATE! AND FACILITATE!
      • #78
        Would that also be for the intake?
        • #79
          very nice, will you be selling the upper part of the manifold that you made?
          • #80
            Looks like Matt is building hisself a Bangup B3 with all the trimmings!
            Once he's finished and posts a thread on his results he should definitely offer up a small batch of initial parts for our drooled upon dollars!
            I'm Jonesing over the thought of B8 headers meself.
            • #81
              Speculation:
              Either there is going to be an air-box around the velocity stacks to retain the VAF
              or
              Independent throttle bodies and aftermarket management system are going to be attached for a great sound.
              • #82
                looks sweeeeeeeeeeeeet!!!! you should try to put the b6 valves in the b3 head... or put a b6 head on it and "fill" the head chambers up with weld to get the compression back... but i think you dont want to start from scratch again lol...
                Mike, AKA the sasquatch
                • #83
                  Im starting with the upper intake first to build components that work well, but come in at reasonable price for reproduction. Eventully i'll be offering a complete intake for more serious power levels . I'M also working on a maf conversion.unfortunatly R & D GETS VERRY costy . I've done R & D for manufacturers such as ARIAS, MANLEY, CROWER, ERSON & several more. The cost for development can be more than the average yearly income for a lot of guys. So im working as i can after i close shop.Being an ELECTROMTIVE dealer i do have an old TECH 2 DFI Laying around im thinking about putting on .
                  • #84
                    Could you do a set up for carb?
                    • #85
                      working on one now for another member
                      • #86
                        Cool want to see pics! Would love to have a setup like this for my 88.
                        • #87
                          ok, i wanted the stacks like that to add a set of motorcycle carbs on my fester..
                          • #88
                            ^ as I said independent throttle bodies
                            • #89
                              ^ word up brotha!
                              • #90
                                A little more done
