exhaust
  • hofficergrover
    replied
    i didn't get a pic of the newer or the old but it allot better then the old has no leaks. i used the 2" just because it's all i had so i will deal with the loss of power and millage.
  • drddan
    replied
    Well in my case, right now its muffler on= less hp+ less mileage
    and muffler off= more hp+ more mileage.
    So I would like to have less restriction and a quiet exhaust.
    Anybody know of a less restrictive muffler, that is quiet as a stock muffler?
    Right now i'd like to just get a muffler that is better, until I change to new pipe. The cat will have to go and either 1 3/4" or 2" exhaust with a good flowing muffler is the plan. I cant imagine using the 1 1/2" pipe that is on there again. Unless, of course, someone can show me that 1 1/2" pipe with less a restrictve miffler is the way to go.
  • drddan
    replied
    Ok, i'm goin' to have to try that!
  • perucho
    replied
    Originally posted by drddan View Post
    Gotta put in my 2 cents! I have the stock 1.5 inch exhaust on my festy.
    Here is an interesting post on what I have experienced as of late:
    My muffler just blew out and guess what? With muffler blown out my festy suddenly got more HP and more gas mileage! I posted about my gas mileage run a week ago and didnt know it at the time, but muffler had already rusted and was leaking, didnt make more noise til about 1-2 days later. Well it was flyin up hiils, breaking tires loose on takeoff, and gas was 46 mpg, which i've never gotten before. My gas post states that this was due to all the work/components I put on, but now... I wonder...
    This weekend I put on new muffler and gee... now it wont hardly climb a hill, lost most of its power, and generally is slow. Feels like i've lost 20 HP.
    This I do know: engines need to breathe! In and Out. Obviously something is restricting about the festy exhaust system and maybe timing needs to be corrected to account for the different size exhaust's/different flows of different mufflers.
    I know I WILL be changing to a bigger, less restrictive exhaust soon.
    After thought: I still have the cat on there, and maybe its gettin plugged up, but the muffler blowing out shouldnt have had an effect if the cat is plugged up? Right? I'll be doing more research on whats happening with the exhaust.
    Well, here are my 2 cents. First, I'm not an expert in fluid mechanics; however, I've taken several classes in physics, fluid mechanics, and thermodynamics when I was in college. The flow in your exhaust pipe goes at a certain speed depending on the engine's rpms. When it enters the muffler, the cross sectional area increases dramatically very abruptly. This causes two things, it slows down the flow (which cools down exhaust fumes and further slows them) and allows the flow to follow the muffler walls. When this happens it creates a low pressure side and atmospheric pressure builds up against the incoming gases at the entrance of the muffler. It is basically the same principle of airplane wings and lift (when air flows faster over the wing it creates a low pressure situation and atmospheric pressure "lifts" the wing). Same thing with main and head sails on a sailboat.
    Anyway, the same principle applies to large exhaust pipes. When the smaller primaries collect on a poorly-designed very large exhaust pipe, you will have the same issues (flow will slow down and cool, and the low pressure scenario will greatly restrict flow.
    Try something fun: grab a funnel and a ping-pong ball. Blow into the funnel's small end and place the ping-pong ball in the large opening. You won't be able to blow the ping-pong ball off the funnel, even if you blow very hard. Atmospheric pressure is pushing on the ball when you blow. You can even blow with the large opening facing down and the ball will stay in place until you stop blowing!
  • perucho
    replied
    Originally posted by willowfarm View Post
    NA motors are going to run differently than injected since they seem to dump more raw fuel into the motor and don't atomize as well as injected...
    Sorry, but unless it has forced induction, it is a naturally aspirated (NA) engine. That goes for carburetted and fuel injected.
  • Pu241
    replied
    ^^^ Uh, not boosted!
    EFI and Carbies are both NA unless boosted via turbo or supercharger.
  • GenevaDirt
    replied
    ^ What is an NA motor?
    Normally Aspirated, (carbed)
  • drddan
    replied
  • willowfarm
    replied
    There is a point at which larger exhaust is doing no good and also the point to where too restrictive is detrimental to performance. In my experience with the Porsche 911 the free flow exhausts built for performance generally cannot be improved on except for sound. Also in my experience with the internal combustion engine in general the exhaust needs to be balanced with the valve train duration and lift and also the intake type and amount. NA motors are going to run differently than injected since they seem to dump more raw fuel into the motor and don't atomize as well as injected, also NAmotors are in my opinion more inclined to load up, not breathe as well and require a tad more tinkering to run well. Any motor if run too lean is going to be proned to burn exhaust valves with todays fuel of low lead types. the ideal situation would be to put a restricted pipe on with a given length and gradually open it up to the best size and over some time and find out where it runs best and make notes. I think you will find they will run just fine with a straight pipe of say 1 7/8 or 2" but the local cops and neighbors are going to notice. I have also done lots of vw air cooled and I have to laugh at these guys that put dual carbs on with tuned exhaust and make no other changes. The most HP from a flat 4 vw with stock pistons and valve train is from the stock 34 pict carb with tuned exhaust, and that is dyno HP. duals look great and do nothing but dump more gas.
  • drddan
    replied
  • hofficergrover
    replied
    pr0nst4r i don't go to a shop i have all the tools to make my own exhaust just no bender i just buy the bends. the exhaust is a bunch of pipes from a parts store and all clamped together. i would weld them but see no matter what the 2" will be installed when i put the bp in it in the spring so if i just do it now i won't have to later.
    GenevaDirt i would love to keep the stock just it is really bad and i don't like it, the 2" will be loud but it is put out the side of the car and not right under you and it echos inside the car and it sucks. the gas millage isn't a big worry because our yellow one has 2 1/2 and does almost 60 miles to the gallon and has over 200,000 miles on it and mine has way less than that. so i am not to worried but i will go over the exhaust and see if it's worth it to patch or just get rid of it. thank you all and i will let you guys know and get a pic later tonight i have to work so can't now.
  • GenevaDirt
    replied
    2" would be fine but I know for a fact that bigger on a stock B3 will cause you to have less torque making the car sluggish.....and believe me....it is very noticeable. I have run it both ways and was very happy when I went back to the stock exhaust. Difference of night and day on take off and pic up when driving. Plus my gas mileage went down with the larger pipe.
  • resuwrecked
    replied
    well this has been a nice discussion, so ill leave you with a research topic: exhaust gas reversion and its causes and effects.
  • pr0nst4r
    replied
    Don't run the 2"
    Insult my idea all you want, but it's unfortunate how it will turn out if you don't.
    /gnight
  • resuwrecked
    replied
    Originally posted by pr0nst4r View Post
    First, never said I knew all.
    Second, why would I always want to speak technically? Sometimes the analogy makes it better. Do you have a problem with joking around?
    First you were trying to defend a loony idea pretty strongly by saying i was misinformed and second the analogy made no sense. a b3 and a race engine are both engines, they are both engines, and all engines function on the same principles.
    Run the 2"!
