Originally posted by pimpinphil
1.6 internal's fit into a 1.3 block????
You don't need to do this. You just need to bash the firewall a little bit with a BFH and if you keep the stock festi tranny you dont need to notch the frame. And if you use the BP+G5M-R you just need to bash the frame a little and allmost no need to bash the firewall with this combo.
sometimes you have to buy a lot of stuff to get an engine.
I love the can't get a date description on the DC listingLast edited by getnpsi; 12-10-2009, 03:26 PM.1993 GL 5 speed
I hope i helped OP on his quest. $400 for a running engine trans and ecu is a fair price. If you get lazy you can just drive the 323 a while!
blkford: I doubt a stroked 1.6 with high compression would run right on OEM controls anyway. This defeats the sleeper and squeak by emissions purposes
If I had to redo an engine harness (dohc's) I might as well would get it inspected and certified with the new engine. To save mass amounts of time a 8v 1.6 with mods still ends up a peppy festiva.
1993 GL 5 speed
I never had to bash the firewall or frame with my BP swap :lol:Originally posted by Maxtiva View PostYou don't need to do this. You just need to bash the firewall a little bit with a BFH and if you keep the stock festi tranny you dont need to notch the frame. And if you use the BP+G5M-R you just need to bash the frame a little and allmost no need to bash the firewall with this combo.
could you maby make a b4.5? take a b3 block and pistons and put in b6 rods and crank? would that work? or maby de-strok a b6 using a b3 crank and rods to make it rev higher?
Mike, AKA the sasquatch
The B3 and B6 have the same stroke. The bore is different. 71 mm for the B3 and 78 mm for the B6Festiva: Because even my dog can build a Honda.
awww
that makes me sad... i thought i woud be able to have a b3 stroker
you can (for $2400)Trees aren't kind to me...
i got 12 bucks...
